EGR Clean
18 replies to this topic
#1 GrahamH
GrahamH
  • 42 posts
  • Name: Graham
  • Ford Model: Mk3 Zetec dtci estate
  • Year: 2006
Posted 25 January 2010 - 01:48 PM
Changed the oil and filter yesterday and decided to clean the EGR valve at the same time. 65k on the clock and I had noticed it made smoke whenever you accelerated hard. When I got it off was ama zed at the state of it. The pipe must be at least 50mm diameter and was all but blocked, you could just get your finger in the middle - all the rest black tarry coke. :o
Cleaned it all out and reassembled; no more smoke! :D
#2 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 25 January 2010 - 02:47 PM
an egr valve clean is a really messy job but well worth the effort did you check the manifold at the same time as its most likely in the same condition?
#3 GrahamH
GrahamH
  • 42 posts
  • Name: Graham
  • Year: 2006
Posted 25 January 2010 - 08:05 PM
Looked into the entry point and cleaned that - wasn't too bad tho.
Should I have taken the manifold off? Given the mileage (65k) I was surprised at the extent of the build up. Seem like a design flaw to me? Thought things like decokes were a thing of the past!
#4 chris bowman
chris bowman
  • 255 posts
  • Ford Model: ford mondeo 2.0lx tdci 115
Posted 25 January 2010 - 08:47 PM
my mkiii 2.0 tdci really was running so rough that i thought that something serious was wrong with it and the symptom completely dissappeared when i cleaned the egr and repaired the intercooler pipe that went into the bottom of it!
#5 Alucard
Alucard
    Newbie
  • Pip
  • 1 posts
Posted 26 January 2010 - 10:22 AM
Hi as you have now cleaned the EGR valve you could now blank the valve off by making up a small blanking plate from a piece of 1mm steel or alloy plate, this would then stop the future build up of the black sludge in the valve and inlet manifold and the engine would then not have to ingest its own exhaust so it will run better and you may get a few more MPGS.
I have owned 3 tdci diesels and have done this mod on all of them and i found it well worth doing just to keep the inlet manifold and EGR valve clean.
Its a easy mod to do as long as you know your way around the engine and the only cost would be a few pence for the metal for the blanking plate i made mine from the base of a old aluminium saucepan! and you should be able to complete the job in an afternoon.
#6 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Year: 2006
Posted 26 January 2010 - 03:34 PM
you can blank it off as long as its not a euro 4 engine, if you do this on the later models it will put a warning light on the dash.
#7 DONFRAMAC
DONFRAMAC
  • 235 posts
  • Ford Model: Fiesta Mk6 1.25 Zetec Climate '58 reg
Posted 27 January 2010 - 12:04 AM
For 8 years, I used "FORTE" brand diesel system cleaner fuel additive, which is available only thro' the trade, at ~£8.50p + VaT, which treats 100 litres of fuel. It has a rapid effect, and has been documented as cleaning EGR valves, as well as injectors/upper cylinders/lambda probes.
I now use the petrol version, in my '58 reg Fiesta 1.25. There is another petrol version for older Zetec S type engines, which had sticky-valve troubles. (pre-Mk 6, the engines which had hydraulic tappets.)
"FORTE" additives are well-known for ensuring low emissions prior to the MoT, and were used by Mercedes workshops, until recently, when a cheaper source was adopted.
The Ford and Vauxhall dealers in my county both use this at services. It can decoke high-mileage diesels within a few miles, when used in high concentration in a low level of fuel in the tank :-- the lack of smoke left behind is astounding, and acceleration gets smooth and silky.
#8 BLUEOVAL09
BLUEOVAL09
    Member
  • PipPip
  • 26 posts
  • Ford Model: MK7 Fiesta Titanium 1.6 tdci
Posted 27 January 2010 - 08:06 PM
Had the same problem with my 05 plate 2.0 130 last year, took the egr & manifold off and cleaned them with brake cleaner and all was well for a few weeks then got the same thing happening. replaced the egr valve completely with a part i found on ebay thats completely smooth inside so the air flow is now much better, also put a K&N air filter in, that made a world of difference, a silicone intercooler hose (not cheap but well worth it as its reinforced and much stronger)and i've just had it chipped, the upshot is at the M.O.T last week the tester had to fault the smoke test machine as the engine was running too clean to give a reading, it's also now returning 46.1 mpg urban & 55.7 on a run :D
#9 baitman
baitman
  • 36 posts
  • Ford Model: Mondeo 2.0 tdci estate
  • Year: 2005
Posted 07 March 2013 - 02:28 AM
i had some issues with my mondeo 2005 tdci, and from doing some reading i reckoned it was the egr valve. i wasnt too confident about tackling it alone, and when my brother came to visit i mentioned it to him and we got stuck in...
my brother is a a keen diy mechanic so when he came to visit i mentioned this problem. he checked out a couple of pages on google to suss out the layout of the EGR valve, we bought some carb cleaning spray and had a go.
the egr was easy to find after removal of the plastic engine cover. the access id quite good, at the front top left in the engine bay. we only had to remove two nuts front, two nuts rear, and a large jubilee clip, then a vacuum hose and two electric connections
the egr came out very easily. it was seriously caked in carbon soot. we cleaned it all off dry, then used the carb cleaner to soften and remove the tougher bits. we had to make a small wire scrapper from a piece of coat hanger to get into the corners.once that was clean we checked up the plastic cover between egr and the valves [dont know the name or how better to describe] and there was some further deposits to remove. you could just about clean them out with a finger and a clean rag. a little squirt of carb cleaner and a last wipe removed the last traces.
after re-assembly i tried to start the car. there were a  couple of little coughs that had me worried, then it fired up ok. the flashing heater plug light was still on, but after running up the road i turned the ignition off and re-started and the heater light didnt re-appear. i was now able to put my foot down and the power is back. started from cold just fine this morning, zero celsius.
very pleased. thanks for the advice chaps. this is not a major garage jobbie.i am guilty of not doing regular oil and filter changes, so this might well have been the source of the problem  i also dont drive the car long distances as i used to do and diesels prefer to be driven until fully warm to keep the soot from building up.
i will be doing an oil change including a full flush, oil, fuel and air filters, then adding some 'forte' diesel treatment [recommended by the brother] to clear out the remnants of the carbon/soot.
the forte treatment was added to less than a quarter of a tank of fuel, and the eml [engine management light] was still on. i took the car for a short 10 mile run on the mway, running at over 80. the eml was still on. stopped at the supermarket on the way home, and when i re-started the car the eml was now out, yippee!!!
the next day i filled up with fuel and all looks good, so far.
i have read with interest about blanking the egr valve. as my car is euro 4, should i use the one with the hole in it. i know some fumes will still get in bit at least the eml will not light up as it would do if i fitted a fully blanked plate. will there be some benefit in fitting the plate with the hole in it or should i just not bother? i dont like the idea of the eml being on in case there was another fault in the future, how would i know...
sorry about the script size. maybe the mods could re-set the bottom part of the text as it might be a little hard to read. thanks.
#10 bladeage
bladeage
  • 82 posts
  • Name: PAUL
  • Ford Model: mondeo 2007 2.0 tdci old shape
  • Year: 2007
Posted 07 March 2013 - 09:08 PM
Firstly the Forte/wynns and other fuel additives that state "clean the induction system" really do, they do this by modifying the fuel flash point of the fuel i.e. making the fuel burn at a quicker and much higher temperature, this then burns carbon deposits away where they would not normally at normal diesel fuel running temperatures.
The instructions of use should be followed as they are devised in the laboratory on a dilution ratio e.g. 25% parts modifier to 100 parts fuel, you seem to have modified the laboratories stated dilution ratio by 75% positive etc,probably wont do your engine much good in the long run if practiced often>?
#11 Badman
Badman
    Newbie
  • Pip
  • 3 posts
  • Name: Ian
  • Ford Model: Mondeo 2.0L tdci
  • Year: 2006
Posted 03 April 2013 - 06:14 PM
I think that I have this problem on my 2006 mondeo, but is it usual to loose all power on hard accelaration? . I get smoke when I give a bit of quick acceleration but if I floor the accelarator the engine will start to go but then loses power and the "glow plug light " comes on, if I turn engine off and restart it is back to normal.
#12 stooge75
stooge75
  • 239 posts
  • Ford Model: Mondeo tdci zetec
Posted 03 April 2013 - 07:56 PM
cleaned out my egr valve & put 1 on,that was off another mk3(euro4).
2 days later,EML came on.scanned it,& 0401 & 0405 appeared.
took egr off,replaced with other 1(thats been cleaned),cleared eml,& its still off.btw I had a tiny hole 3or 4mm(slit) on vacuum pipe.taped it up for now.
i remember putting the boot down other day,& a bit of smoke(bit more than usual) appeared.I think the egr valve mustve stuck(no wonder he sold it to me for a fiver lol)ah well,ya pay peanuts,ya get monkeys*it
#13 baitman
baitman
  • 36 posts
  • Year: 2005
Posted 03 April 2013 - 10:02 PM
i do agree with what you have said with regard to the inclusion levels of the diesel additives. i only used a concentrated level to help clean out the fuel combustion system and egr as a short term option. the following day i topped up the fuel tank and so diluted the additive to the normal sort of inclusion levels.
a few days later, and after short journeys that didnt allow the car to get to full temperature i found the glow plug light/limp mode returning. i ordered a solid egr blanking plate and then took the car for a decent run. the car ran great, and the forte must have been clearing out any residue rubbish. the following day i fitted the egr blanking plate [the solid one] and it was nice and easy to just slacken off two bolts and slide it into place. the car is driving great, excellent mpg and power, and no glow plug light or EML coming on.
#14 bladeage
bladeage
  • 82 posts
  • Name: PAUL
  • Year: 2007
Posted 04 April 2013 - 07:08 PM
Hi Baitman,
Yeah the egr/dpf inlet/induction cleaner stuff you add to the tank is basically airline jet engine fuel (kerosene/parafin), I am an aerospace radiologist concerned with the diagnostics on stripped down jet engines and their rotating parts and can tell you there is never any soot or deposits to be found anywhere on the combustion side of things and very little on the exhaust side either.
Kerosene not only burns at a much higher temperature but acts as a catalyst on carbon/soot;I am not an expert but basically kerosene is able to penetrate carbon/soot deposits via a chemical (maybe other) reaction and release it from where it is stuck /adhered to, it really is good in diesel engines as diesel engines run very cool and get sooted up quickly if not run at high temperatures often.
Good stuff! but not sure it should be run at low dilution levels in an aluminium engine,kerosene has a very high sulphur content which absolutely reacts with and destroys aluminium, jet aircraft engines and there moving parts are mostly (90%) made from Titanium which does not readily react with sulphur at high temperatures....get my drift?! The manufacturers of the said tank additive all state it should not be added more than every 3,000 miles approx.
Another good point to make which is off topic!
Red Diesel !
How many out there think red diesel is just normal diesel with red dye added to catch tax cheats out???????
Red diesel for the less informed has at least (approx) 125% more phosphorous/sulfur content than its more refined cousin...white diesel.
Sulfur/phosphors absolutely eat aluminium away, cylinder head,valve seats,turbo's etc etc,just ask the multitude of merc sprinter owners that continued using it in there new alloy headed vans back in the 1990's....lol...my mates head gasket went 3 times in 12 months, not due to the bad workmanship of fitting the gaskets but from the porosity it caused where the sulphur had been trapped.
cheers.
#15 stooge75
stooge75
  • 239 posts
Posted 04 April 2013 - 07:43 PM
Changed the oil and filter yesterday and decided to clean the EGR valve at the same time. 65k on the clock and I had noticed it made smoke whenever you accelerated hard. When I got it off was ama zed at the state of it. The pipe must be at least 50mm diameter and was all but blocked, you could just get your finger in the middle - all the rest black tarry coke. ohmy.gif
I'd be willing to bet you,that if you put your foot down,the exact same way as you did before you cleaned your egr,that you'll get the smoke appear,under load.(unless you've blanked it off).
