james_60
error codes on the new fiesta
Hello
Picked my new fiesta 1.4 titanium up today.
Went into the secret menu and found the following message
Rca
Er0136
E01
dtst60
dt1F0E
What are these numbers all about.
Iam really pleased with my new fiesta.
Jamie
How you access the secret menu? :S
and there shudnt be error codes if its brand new!
Hi
The secret menu's are activated by pressing and holding the trip reset button whilst turning the ignition on.
Jamie
Hi
Jamie
doesn't work for me :(
Follow these steps
Use the reset button on the speedometer/Tach not the the one on the end of the indicator stalk
With the ignition off press and hold in the trip reset button on the dials.
Whilst still holding the reset button turn on the ignition.
It should say TEST and then GAG£
i will take some pics but iam sure someone else will beat me to it.
Jamie
How do you know they are "errors"
They may be setting codes for the UK spec or something similar?
You find errors by using the diagnostic contact to the bottom right of the steering wheel,not the trip computer toggle
I dont have the full fiesta 7 spec to hand ,but this is the list from an earlier ford gage test
Some of the different Functions
Functions
1 Gage Test
2 Dial Test
3 Bulb Test
4 Diagnostic Check
5 Diagnostic Check
6 Clock Type (shows 44 if UK)
7 Diagnostic Check
8 Speed MPH
9 Speed KPH
10 Revs
11 Fuel
12 Engine Type
13 Temp of Engine
14 battery Voltage
15 Diagnostic Check
16 LCD Display
Dave
managed it that time i had Er0121 and e01 christ knows what the rest of the stuff means lol
Hello
They may not be software errors.
Is anyone with the knowledge able to compile a list of what these things mean for the new fiesta.
I note that the charging voltage is lower on the new fiesta. When i used to check my 07 plate fiesta it used to show 14.3v when charging this car only shows 13.4v
The new car is so much quieter
Jamie
Hello
Jamie
what use is this display, im not really sure what to make of it. :blink:
Just made some enquiries,
Diagnostic Trouble Codes are a letter and 4 numbers, eg A1234
What you are reading are car settings,such as miles rather than kilometers.
i guess this is handy for making sure all your warning bulbs are working other than that i cant think of any other benefits of accessing this menu?
Jamie
Sorry for being really thick,but are you complaining about this or suggesting its a good point?
Can I also suggest you change the title of your thread as you clearly havent got "error codes" as you claim,you merely have regional setting codes.
dave
My fez just displays the word test then dosent do anything else :S
keep pressing the test/reset button and it will scroll through the rest of them
sure I tried this but i'll have another go tomoz :)
There is absolutly no reason to look at this menu but I like messing with the fez :lol:
Hi
Iam sorry maybe i was wrong about whether or not they are error codes and i do not know how to change the title !
Jamie
Stumbled accross this whilst im trying to trouble shoot one or two issues with my car. For those that have tried, is anyone able to confirm the speed readouts when in using the readouts?
Currently when driving and looking at the MPH or KPH readouts in this 'secret menu' the speed on mine appears to be current speed x 10, i.e if im travelling 29 MPH the readout is 290, or 50mph - 500. Can someone else confirm this?
I also have Er0136 on the dash, thought it may have been an error but turns out with others having it, it must be quite normal!
