cam sensor
1 reply to this topic
#1 davidh08
  • New Member
  • Pip
  • 3 posts
  • Ford Model: 2003 focus 1.8 tdci 115ps
Posted 27 January 2010 - 03:45 PM
Doe's anyone know where the cam sensor is on a 2003 1.8 focus tdci?I need to check if it's the uprated wiring plug as i am having cold start issues - is the crankshaft sensor the one underneath the car going in sideways into the crankcase, it had 3 small pins sticking out of the sensor - if anyone can point me to some pictures of these or a link - thanks in advance David
Have something to contribute?
#2 Slugsy
  • New Member
  • 57 posts
  • Ford Model: Focus ST170
Posted 05 February 2010 - 02:14 PM
cam sensor should be between both cams coming in from the top of the engine. Crank shaft sensor should be where you said i think and if it has a flywheel sensor its usually mounted just above the gearbox and mounts to the block i think
Not what you're looking for?
