paulevans
wiring help
4 posts in this topic
hi all new on this site and would really do with some help
i have just bought a 1.8 diesel ford fiesta flight (1997)
trouble is when i bought it there was no stereo but luckily for me i have a cd player and fascia ready to go in
the hole where the stereo is is just full of wires with no connectors on the end so bought and iso conecter ive managed to wire the Speakers up but im stuck on the power cables and the rest of them there is five wires left and im getting confused and dont want to run the risk of shorting anything out
so the wires i have left are as follows
two skinny orange and black wire
one skinny green and black wire
one thick green and black wire
and on thick blue and black wire
thanx for your help in advance
the progblem is almost every ford has a different colour ie youre fiesta colours wont match anothers ive found these diagrams for youre fiesta and they dont link up
Battery / MemoryGreen / YellowYellowIgnition / AccessoryYellow / BlackRedGroundBlue or RedBlackPower AntennaBlue (Varies)BlueAmplifier Turn OnN/ABlue / WhiteIlluminationBlue / RedOrangeDimmerN/A
you need a voltage tester first thing toi do is check each wire with ignition off and no key in look for a wire that shows 12v this is the permenant live memory make a note which one it is now take the key put it in the ignition and turn 1 click only now look for another wire showing 12v this is the switched ignition wire make sure by keeping the tester on switching the key back to 0 it should now show no voltage its aguess between which of the 2 thicker ones is the earth ide go to the scrappy and cut a plug off another fiesta make sure the wires are the same then connect it up to ure wires using solder and heat shrink
kk kwl thanks mite go the scrappy tomorrow and have a look around see what i can find thanks for your help will let you know how i get on
well just to so thanks for replying and helping me finnally figured it all out and felt so proud of my self as its the first time ive done that and also fitted two jbl 6x9's on the parcel and succesfully fitted a sub and amp in the boot so was a good all round day for me so admins you may close this thread now thanks
paul
