Sign in to follow this
Followers 0
Reduce, Reuse And Recycle
I have removed my rear bumper panel today and left it in the body shop to get the Zetec S rear skirt painted and fitted to it,
i had to remove it as i need the car to travel to work so in a bid to continue to be 100% road legal i made up some fog light and reverse light housings,
using some PVC electrical tape, some cable ties and two 2ltr CocaCola bottles.
first i removed the bumper,
then i cut the bottle in half, just below the label,
then cut a hole from the bottom centre of the bottle, just enough to allow the bulb to stick through,
once the bulb was through i held it in position with some electrical PVC tape and also around the side of the bottle to ensure all of the light is expelled only from the rear of the unit.
followed by cutting two slits in the top for the cable tie to pass through and grip to the chassie.
and here are the results
Im now sitting by the letter box,
awaiting my Blue Peter Badge for this one http://www.fordownersclub.com/forums/public/style_emoticons/#EMO_DIR#/laugh.png
0 Comments
