Sign in to follow this
Guide Additional 12V Power Socket In Boot Focus Mk2.5
On the right hand side of the boot compartment on the Mk2.5 Focus and possibly the mk2 also,
their is an orange plug which is a positive feed for a 12v power socket,
the only additional items required to connect is a earth cable and a 12v socket,
attach a female spade connector to the earth feed and push it in to the slot next to the positive feed,
then push the orange connector on to the rear of the 12v power socket,
finally choose a location on the panel you would like to mount the socket and drill the hole.
their is power already being fed to the orange plug so their is no further wiring required.
I Purchased Ford 12v Power supply kit Finis Code: 1021887 this kit has since been discontinued by ford,
but if you wish to purchase the 12v Socket with out the earth cable the Finis code is:1333905 and costs less than £5
once you have that part you just need to make up an earth feed using a female spade connector and a ring terminal on the oposite end.
it contained the 12v plug and cap
4metres of positive cable which i didnt need to use for fitting,
1 metre earth cable with female blade connector and ring terminal attached,
and 8 cable ties which i didnt need to use.
but this orange plug will work with any 12v socket that has 2 pins on the rear like this one found on ebay
http://www.ebay.co.u...=item27ba8d09b7
I have crimped a ring terminal on to the opposite end of the earth feed cable,
and put it on to the screw that holds the panel in place like a washer then screwed the panel back in to place,
i now need to purchase a holesaw bit to fit the diameter of the 12v socket.
When finished
and the panels are back in place,
take care to ensure the rubber boot seal over laps the plastic interior around the boot opening, to avoid any leaks.
 Report this tutorial
0 Comments
