Sign in to follow this
Followers 0
Focus Dashboard Secret (Trick)
Description
This guide contains the thread initially started by Matt, and also includes other useful feedback and comments from other members!
Hello all ,
I have found some info out a few months ago about my focus i got it off a ST170 SITE so credit does go to them but i will say it here anyways
*******WARNING DO NOT TRY THIS IF YOU LIKE TO KEEP A CHECK ON MILEAGE AFTER EVERY REFILL LIKE ME AS THIS WILL RESET THE TRIP METER******************
1.GET IN FOCUS
2.PUT KEY IN STEERING LOCK OFF
3.HOLD DOWN TRIP RESET BUTTON ON INSTRUMENT PANEL
4.TURN IGNITION ON AND START ENGINE
5.NOW YOUR CAR IS IN SELF DIAGNOSTIC MODE
YOU CAN NOW CHECK IF THE CAR HAS ANY DTC CODES IN THE MEMORY ,CHECK ALL GUAGES ,CHECK ALL INSTRUMENTAL PANEL LAMPS EVEN ONES U DONT USE E.G. ABS GLOW PLUG LIGHT ON PETROL AND AUTO GEARBOX LAMP YOU CAN ALSO SEE YOUR REV METER IN DIGITAL
Give this a go its quite cool and also dtc codes are usefull if you know what to do with them try googling dtc library there used to be a program you could get but i dont know if its avaliable anymore
Matt biggrin.gif (Matt_Focus_Zetec)
(Courtesy of Brunomedina)
Self-Diagnostic Mode - Instrument Cluster
1. To enter the instrument cluster self-diagnostic mode simultaneously
depress and hold the tripmeter reset button then turn the ignition switch to position II or III.
2. Release the tripmeter reset button when TEST is displayed on the LCD. This will take between 5 and 8 seconds.
3. The instrument cluster will enter the gauge sweep test.
4. To navigate to the following tests while in self-diagnostic mode depress the RESET button to move to the next test.
5. The self-test is deactivated when the ignition is turned to the OFF position.
#.Test
#.Syntax Displayed
#.Gauge/Indicator/Display Tested
#.Description
#.1..Gauge sweep.
#.GAGE.
#.Tachometer, speedometer, temperature and fuel.
#.All gauges go through a full up and down pointer sweep smoothness check, which takes approximately 5 seconds.
#.2..Fill in all LCD.
#.8888.
#.LCD display built into Speedometer.
#.Fills in LCD display therefore seeing if display functioning correctly.
#.3..Indicator bulbs.
#.BULB.
#.Instrument cluster illuminates indicator and warning indicators.
#.Illuminates all the warning indicators that are controlled by the instrument cluster.
#.4..ROM level.
#.rXXX.
#.Instrument cluster read only memory (ROM).
#.Displays the instrument cluster ROM revision level.
#.5..NVM level.
#.EXXX.
#.Instrument cluster non volatile memory (NVM).
#.Displays the instrument cluster NVM revision.
#.6..DTC.
#.XXXX or NONE.
#.Diagnostic trouble codes (DTCs).
#.To list the DTCs stored, press the RESET button.
..REFER to the instrument cluster diagnostic trouble code (DTC) index below.
..The DTC codes will scroll through if there is more than one.
#.7..Road speed mph.
#.XXX.X.
#.Speedometer.
#.Displays the speed signal input in mph.
#.8..Road speed Km/h.
#.XXX.X.
#.Speedometer.
#Displays the speed signal input in Km/h.
#.9..Engine speed.
#.XXXX.
#.Tachometer.
#.Displays the tachometer input signal (RPM).
#.10..Fuel volume.
#.FXXX.
#.Fuel sender system.
#.Displays the fuel volume signal input.
#.11..Coolant Temp.
#.XXXC
#.Engine coolant temperature.
#.Displays the engine coolant temperature signal input.
#.12..Battery Voltage.
#.bXXX.
#.Battery Voltage (t).
#.Displays battery voltage input.
#.13..ABS fail.
#.Ab-[H/L].
#.ABS system.
#.Displays ABS raw cluster input. (H = open-circuit, L = ground).
#.14..Electronic Brake Distribution Failure (EBD).
#.Eb-[H/L].
#.EBD system.
#.Displays EBD raw cluster input. (H = open-circuit, L = ground).
#.15..Illumination.
#.IL-[H/L].
#.Cluster and instrument panel illumination.
#.Displays instrument cluster and instrument panel illumination. (H = ON, L = OFF).
#.16..Crank Sense.
#.Cr-[H/L].
#.Cluster and instrument panel crank sense.
#.Displays Cluster and instrument panel Crank sense. (H = Ignition, L = Ground or over-charging).
#.(Crank sense it the Pos I (Accessory) supply to the cluster. If this
is missing then the cluster will remain dead for about 20 seconds after
key on. Then it will function normally. This can happen when someone
fits a radio and blows the accessory fuse).
Note:
Additional tests are available after number #.16 but are not useful for diagnostics.
Note:
Later vehicles had a "cost reduced" cluster that had a different
Engineering Test Mode layout. These came in about 03-53 reg, and can be
distinguished by only the symbol lighting up in the tell tale rather
than the whole lot. (LEDs rather than bulbs).
These clusters used stepper motors for the gauges rather than the air cored ones and did not have a Gauge Sweep test?
Self ..........DTC.......... Description
Diagnostic
Mode
Displayed
DTC
9202 ..........B1202.......... Fuel pump module circuit open
9204 ..........B1204.......... Fuel pump module short to ground
9342 ..........B1342.......... Instrument Cluster ECU is defective
9317 ..........B1317.......... Battery voltage high (greater than 16V)
9318 ..........B1318.......... Battery voltage low (less than 10V)
9359 ..........B1359.......... Ignition Run/ACC circuit failure
A143 ..........B2143.......... NVM memory failure
A477 ..........B2477.......... Module configuration failure
D041 ..........U1041.......... Invalid data for vehicle speed
D027 ..........U1027.......... Invalid data for engine RPM
D073 ..........U1073.......... Invalid data for engine coolant
D262 ..........U1262.......... Missing speed, tacho, engine temp, or dometer count
D123 ..........U1123.......... Invalid data for odometer
Courtesy of Sid_WRC.
i've just made a video showing and explaining how to run this diagnostic in my focus and my mums s-max
Courtesy of Queenmix:
List of DTC Codes can be found here as well: http://www.fordst170.co.uk/dtc-codes.php
Courtesy of Hawker:
Heres a useful link of more codes in case anyone is interested.
DTC Codes
Courtesy of Preee:
Has anyone managed to get this trick to work with a Keyless Ignitiion "power start button"? Focus 2010
I tried , holding the reset button on the trip lever , "no trip reset on center dash" and starting the engine with the button continued holding for about 12 hrs and still nothing .lol.
Tried placing the "key" in and doing the same , nothing happens apart from reseting the trip. BTW key does not turn so can't get II and III positions.
*EDIT* - Got it to work.
On keyless power start.
1)hold trip reset button in.
2)Short press half way down of the power button , displays II position lights.
3)Continue to hold trip reset button.
4)Menu comes up and click trip reset button to scroll through .
Courtesy of Bass Junkie:
For DTC help please find the following link
http://www.eobd2.eu/DTCL.asp
select FORD, then enter your DTC code. Should be one letter followed by 4 numbers, however your dash may not show the proper code.
For instance if the code shown is P117, enter it as P0117 and it will give you what the error is. P0117 is Engine Coolant Temperature Circuit Low Input.
0 Comments
