• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
! Guide ! Fitting A 12V Socket In The Boot Mk7
One thing I find lacking with the Fiesta is not having a 12v socket in the boot for running accessories or a cool box when going out for the day - so I decided to fit one.
Here’s how I did it.
Firstly the parcel shelf support trim needs to be removed. This is best done with the rear seat reclined:
Now for the wiring.
For my requirements I need around 7A. That is too much to load onto any existing circuit around the rear of the car, so I decided to run a new feed from the fuse box.
I ordered 5m of thinwall 11A cable. When it arrived I was surprised at how thin it was!
After some reassurance from the supplier that it will be fine (fingers crossed), I also ordered a fuse adaptor, a 10A fuse and various crimp terminals.
I then set about installing it all.
To access the fuse box behind the glovebox, first empty the glovebox and squeeze the sides together so that the glovebox can open fully exposing the fuse panel behind.
 Report this tutorial
0 Comments
