• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
Access Rear Light Bulbs On Mark 7
1. Open boot and remove the 2 screws attaching the light cluster to the back of the car. A small flat blade or a torx 25 screwdriver will do it.
2. Inside the boot pull back the side carpet behind the cluster. Starting at the boot-latch end ease out and pull back the carpet all the way to about halfway back towards the rear seat. There are no clips to break it should come out pretty easily
3 You now have access to the back of the light cluster. There is a small rectangular hole there and just inside that you will find a long wingnut. Unscrew and remove
4. The cluster can now be eased out. There are no clips to break, just 2 push studs on the outside of the cluster which can be pulled out of the back of the car.
5. Before removing it too far disconnect the wiring block at the back so that the cluster becomes free.
6. The bulbs are held into the cluster by two clips - press those back and the bulb section can be removed
 Report this tutorial
0 Comments
