AdBlock Warning
Sign in to follow this
! Guide ! Mk7 Fiesta Grill Removal
Hi everyone
I know a few people including myself have been asking about how to remove the front radiator grill of the MK7 fiesta, so when i got my asian spec grill i decided to make one smile.png hope it helps everyone
First thing first this is a really easy job, took me no longer than 15 minutes and i didn't need any tools, just my hands and a bit of careful persuasion.
If possible get the car to a comfortable working height, i had access to a ramp but it really isn't needed, this grill is only held in by clips so no hidden screws to worry about smile.png
Best technique i found was start in a corner, i chose bottom left (no real reason for that) then with hand pressed firmly on the bumper and one hand holding the grill give it a short sharp tug, there will be a bit of resistance but if there is to much don't try and force it out cause you may end up breaking something, just move on to a different part of the grill
Once you have one side of the grill out start working your way to the other end pulling the top and bottom alternately all the time keeping one hand on the bumper as you pull the grill, as a little tip try and keep the grill parallel to the bumper as this stops you stressing the clips and makes it easier to remove. By the time you get to the other end it should just pull out nice and easy, once again don't try and force it if it seems stuck, just move on to a different section of the grill.
Once the grill is removed your left with a toothless looking fiesta lol, reinstalling the grill is pretty simple whether your just putting the old one back in or like me putting in the Asian spec unit.
One thing i would say about the reinstallation is there are little locating points all around the grill ( if you look at the picture above you can seem them pretty clearly) make sure when you put the grill back in you slide the lip of the grill under these locating points or you'll have a very messy grill fitment.
Once its all in the car should look good as new smile.png in my opinion with the Asian grill better than new biggrin.png
Hope this guides helps, any question please to hesitate to post on this guide and answer as best i can
Rob
 Report this tutorial
0 Comments
