• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
Removing Fog Light Inserts And Lower Grille On A Mk7 St
Fog light inserts first:
Now lower grille:
Just make sure you don't yank it, nice slow pulls and you should be fine :)
Welshy_Maverick. This thread is dedicated to you :P
 Report this tutorial
0 Comments
