AdBlock Warning
Fiesta Mk7 MK8 under door puddle lights install
Firstly you will need to remove the door card as you will be mounting the lights underneath them and wiring behind the door card
tutorials-43230-0-94792400-1386976811_th
tutorials-43230-0-49578900-1386976826_th
after you have removed the door card, you will then need to slowly pull on the rubber tubing from which all the wiring is running through. You will then to run the led wire, for this you will need to use the metal hanger and then tape on the wire from the light and push it through.
Removing your glovebox would be a great help as there is a flap from were the wire will come through. i wired my lights using scotch clips in to the footwell lights.
tutorials-43230-0-63802800-1386977044_th
once you have tested the lights work correctly, you will then need to stick them down on the bottom of the door card. for this i used glue as the sticky tape on the led strips was no good.
tutorials-43230-0-82693000-1386976841_th
once secured in the desired place, secure the wire on to the door using gaffer tape as you don't want the wire vibrating due to the speaker. Refit the door card and away you go
 Report this tutorial
0 Comments
