• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
*Guide* Loading Bluefin on your EcoBoost Fiesta 100 / 125 / 140ps
Description
Guide and links for anyone wanting to remap there fiesta using a bluefin device from Superchips.
100ps Technical data and link to buying handset
http://www.mybluefin...=1&variant=2866
125ps Technical data and link to buying handset
http://www.mybluefin...=1&variant=2870
140ps Technical data and link to buying handset
http://www.mybluefin.co.uk/search?make=9&fueltype=3&model=1&variant=3075
Genral info
http://www.mybluefin.co.uk/s/software
Files
http://www.mybluefin...oftware/bluefin installation . zip
http://www.mybluefin...sta_drivers.zip
The install is really easy.
1. Plug the Bluefin handset into your OBD port. This is found to the right of the steering wheel in a little cubby hole near your right knee.
2. follow the easy instructions on the Bluefin screen. It will ask you to turn your ignition on (DON'T start the car) and follow a set of instructions. It will save your cars original map onto the handset which takes about 10 minutes. once done turn off ignition, remove handset.
3. Install the Bluefin software from Superchips on your PC/laptop (Mac isn't compatible)
4. Plug the Bluefin handset into your PC with the USB cable provided. wait for the drivers to be installed. Run the Bluefin software and enter your personal details (internet connection required)
5. Connect to there server and upload the handset.
6. Wait for your map to be sent to you via email.
7. Connect handset to PC and run the Bluefin software. Click connect and wait for the map to load to the handset
8. Now out to the car an plug into the OBD port again. Turn ignition on (don't start)
9. Follow the on screen instructions.
Your car will start getting a bit unsettled at this point and display some interesting errors. Just ignore them and carry on.
10. Once its all installed you'll get this message
Keep following the remaining instructions then your done.
 Report this tutorial
4 Comments
