Sign in to follow this
Followers 0
Fiesta Mk7 Wheel Spacers Install
hello all, today i installed my rear wheel spacers and will show you how i did it
first off you need the spacers
here:
tutorials-43519-0-82857800-1395417925_th
tutorials-43519-0-53710900-1395417938_th
i got ebiach 15mm pro spacer heres the link from puma speed
http://www.pumaspeed...-4-STUD_866.jsp
right so first off i needed all the correct tools
a big rachet spanner, a jack, the locking wheel nut adaptor and then we can begin
tutorials-43519-0-45206300-1395417980_th
tutorials-43519-0-15417200-1395418021_th
making sure the car is on a level surface jack the car up from the rear axel beam until both wheels are up off the floor
then using a 19mm socket i removed the normal wheel nuts, and then the anti locking ones,
tutorials-43519-0-67637700-1395417999_th
tutorials-43519-0-20296300-1395418041_th
now my wheels were stuck on so i lowered the car so the wheels sat on the ground so they came loose
jacked the car back up again and removed the wheels remembering to get the little plastic adaptor off to for the alloys,
then placed the spacers onto the wheel studs and put them on with the nuts provided and tightened them to 100nm on both sides,
tutorials-43519-0-74113700-1395418871_th
then put the plastic adaptor back on then the wheels and tightened the nuts on and the locking nut to 100nm then lowered the car carefully
when back on the ground check for tightness again, take it for a spin and see the difference, i went for a 50mile drive to check everything was ok then check they are still tight when you get back and all done :)
before
tutorials-43519-0-03549100-1395418066_th
tutorials-43519-0-62744400-1395418092_th
tutorials-43519-0-96050500-1395418116_th
after
tutorials-43519-0-74817200-1395418144_th
tutorials-43519-0-10535400-1395418822_th
tutorials-43519-0-36413400-1395418849_th
tutorials-43519-0-86083600-1395418893_th
tutorials-43519-0-99295600-1395418922_th
hope this helps people
deno3 likes this
0 Comments
