• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Ford Fiesta Mk7.5 Rear Diffuser Upgrade (ST)
Heres A Guide To Help The Removal/Fitting Of The Rear Diffuser On A MK7.5 Fiesta Zetec S To An ST http://static.autocl...IR#/biggrin.png
tutorials-44466-0-89697500-1396187241_th
These are the parts you will need/require....
£52.76 Upper Honeycomb Deflector- 1819019 (Ford Part Number)
£63.26 Lower Primed Deflector- 1818433 (Ford Part Number)
Both parts above can also be purchased at pumaspeed and european parts (higher cost)
£29.99 Ripspeed Twin Tail Pipe-
http://www.halfords....tegoryId_165537
tutorials-44466-0-86691300-1396186494_th
2x 6mm Plastic Flanged Nut-
http://www.ebay.co.uk/itm/M6-6mm-NYLON-WASHER-FACED-FLANGED-FULL-NUTS-PLASTIC-FLANGE-MODEL-CIRCUIT-/190989084545?pt=UK_DIY_Material_Nails_Fixing_MJ&var=&hash=item2c77d62781
Self Tappers 6mm Or Ford Pot Rivets (Part Number:1555829) -
http://www.ebay.co.u...item4615ff6278
Process (Once Lower Diffuser Part Has Been Sprayed Colour Choice)
Cost Me £50 To Have It Professionally Sprayed Candy Blue
1. Firstly getting the back of the car onto axle stands or ramps etc will help with and makes things easier with more room.
2. Then you will need to remove the pot rivets from the original diffuser, i found a 6mm drill bit worked perfect when used in the centre (be careful and take your time, so you dont push the rivet into the plastic as you drill as the plastics only soft) until the pot rivet head comes off and then the centre of the rivet can be pushed out of the hole. There's three on each side under the corner flaps.
tutorials-44466-0-96016700-1396185566_th
3. Once the pot rivets are removed you can then slowly give the diffuser a pull from corner to corner and as it starts to come away, a flathead screwdriver helps to push the tab ledge in to remove from the slot.
4. You can then fit the two parts of the new ST diffuser together, they simply align together and then tabs fit into the slots and lock it in place.
5. Once the two diffuser parts are together you can align it to the rear of the car and start to push the tabs of the upper part into the bumper of the car, give it a gentle tap with your palm once aligned and check its all flush to the bumper.
6. You can then screw the self tappers into the holes of the new diffuser and should line up with some of the holes of the old diffuser or if you've got the original ford pot rivets (Part Number:1555829) then put them in and tighten up using a pot rivet gun.
7. Also while there the 6mm flanged plastic nuts can be fitted to the two tabs in the centre of the new ST diffuser using a 10mm spanner or 10mm socket.
tutorials-44466-0-39653600-1396186807_th
8. Now the new diffuser is fitted and secure, give a final push to make sure its all pushed in and flush with the bumper. You can then proceed to cutting a couple of inches (the bend) from the original exhaust. I used an air grinder with a cutting disc and slowly went through it straight up.
tutorials-44466-0-61562600-1396186967_th
9. Then you can put the twin tail pipe (chosen exhaust tail) onto the straight part of the remaining original exhaust, align it until your happy with it and then tighten it up with a 10mm deep socket or spanner.
tutorials-44466-0-94086200-1396187079_th
10. Congratulations you've then got your new ST diffuser fitted and should look something like this...
tutorials-44466-0-64023300-1396187384_th
tutorials-44466-0-04436900-1396187487_th
tutorials-44466-0-78512000-1396187526_th
Total Cost= £196.01
Hope this helps and if anyone has any queries or questions dont hesitate to drop me a pm, always happy to help.
And
Thanks Again to E5GDM (He did it first) for the idea and information towards this cosmetic modification/upgrade
 Report this tutorial
6 Comments
my car hasn't got the corner flaps but going to buy them are they easy to put on to bumper? and would i need anything additional to installing this :) ? (standard titanium) and if anything else needed just say i only have original one atm :D
Share this comment
Link to comment
hey guys been quiet recently lol but back
and got a few things in the works lol :P
so got a few plans for ma car nd a seen a different diffuser but wondering how to cut the exhaust?
Share this comment
Link to comment
