• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
Fiesta Mk7 and 7.5 Dual Fog Upgrade
ok to start of with, i was pretty jealous of the focus as you could have dual fogs which look loads better imo.
so things you will need
LHD fiesta fog light unit and found this
http://www.ebay.co.uk/itm/261284682018?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
if you ask them for the fog unit for a LHD car they will send you one around 3-4weeks as its from italy.
you will need these
tutorials-43519-0-47412900-1402000192_th
and one of these
http://www.ebay.co.uk/itm/291070445651?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
and these Cree Q5 red led Fog lights
http://www.ebay.co.uk/itm/270904692782?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
so first thing first the light holder doesn't quite fit the fog unit so a little modification i needed as in the picture i have to cut away some little slots for the holder to sit ok and sealed in place with the led in place
tutorials-43519-0-96345300-1402000188_th
tutorials-43519-0-92328600-1402000190_th
so once thats done the i cripmed the bulb holder to some cable and used some little power sharers to power the new fog light
first out at the car i removed the tow cover and then the diffusor so i had more access, then i removed a little tab so i could pull the bumper out a little
and after removing just 2 screws but a whole lot of time and hassle later due to no space to work the reflector unit is out
tutorials-43519-0-37800800-1402000184_th
it would have been easier to remove the bumper but hey ho
then after wrestling the new fog unit back into place, putting the 2 screws back in and making it line up and tiding the cable up around the crash bar with some cable ties, i also changed the original fog bulb for the cree one so they look the same.
so here is the result
tutorials-43519-0-73659600-1402000195_th
then i just reattached the diffusor and added the tow cover and job done :)
looks so much better!!!
tutorials-43519-0-53831800-1402000182_th
 Report this tutorial
1 Comment
