• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
Focus Mk2 Driver Door Lock Fix
Description
Fixing a door lock that will not operate the lock at all.
I´m posting this for informational purposes:
I own a mk2 station wagon with "Comfort pack". The other day i noticed that the drivers door wouldn´t keep the car locked, with or without the key in proximity, the darned thing would always unlock!
First i tested the electronics - thought that perhaps the keyless entry would be shorting... but no...
Then i got a second opinion, took the car to a specialized electrician who confirmed my suspicions.
So i took the door apart - and took out the lock. So it turns ou to be a small spring on the latch which wasn´t doing it´s job properly. In the enclosed picture i have pointed ou the spring in red. All i had to do was to "open" the spring arms a little, (be careful with the load) and put it back together!! Working like a charm now!
 Report this tutorial
0 Comments
