• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
abs fault light on fiesta style
Description
Fault diagnosis
Had abs fault light came on , phoned the dealer .
£100 labour
£70 fault diagnosis
£89 wheel sensor .
Bought 3 adaptors claiming to be able to diagnose , none worked
Emailed a guy called dominator auto diagnostics , explained the problem and he said for £50 he would provide an adaptor
and software and it would work .
Loaded the software on a windows laptop , connected the adaptor to the car , it said the front offside sensor had no output.
Bought a sensor on ebay for £15 took 10 minutes to replace and bingo abs light went out after 100 yds drive
 Report this tutorial
0 Comments
