Guide info
  • Added on: Aug 26 2014 07:02 PM
  • Date Updated: Sep 04 2014 08:15 PM
0 Ratings
Ford Focus bonnet lock problems....Solved!!!!
Posted by casford on Aug 26 2014 07:02 PM
Hi All
        I have been searching high and low trying to find an answer to the locked bonnet saga! and came across a very good guide on this website, but either I'm thick or just not following instructions correctly but just could'nt get my head around the screwdriver in collet workaround supplied by Brigante simply because I could'nt see the cable or the collet through the grille, panick time had now set in because it looked like smashing the grille to get a better look at what I was supposed to do and what if that didn't work then what!
        So what did I do to solve the problem, simply put the spare key into the ignition turning it but not starting the engine, then with the main key I tried it in the bonnet lock (the one that had refused to open for over a month!) I turned the key as normal....and in my amazement it opened :) what a relief
