Sign in to follow this
how do you connect DRL to ignition switch
Description
how to connect drl's to ignition so that they come on when ignition is turned on. can you just put a fuse into fuse box?
got some drl's and a relay to go with them that just dimes them when headlights are turned on. however having problems wiring it all up. the relay is a drlm2 i think. and has to be connected to ignition system, but i dont know how to do this in the fuse box there is a space for 'daytime running lamps' as said in manual. can i just put a new fuse in there, and if so may sound stupid but how do you do that? pictures would be a great help if possible.
many thanks.
 Report this tutorial
0 Comments
