• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
kuga engine problem
Description
stutters at speed
when going up hill the 2 lit td 4x4 2008 model surges on the revs  and from 40mph to 80 mph if you set you speed ie 60 mph it stutters all the time.
the company have changed the mass air flow valve,/ the fuel fillter./ checked all injectors,done a ecu upgrade./changed the erg valve,/ what else can be the problem ???????
 Report this tutorial
0 Comments
