• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Fiesta-van 1.4tdci Starting problem
Description
Motor starts and dies after 2 seconds
I had a starting problem with my fiesta1.4tdci.  The motor cranked and ran for about 2-3 seconds and then stopped. This happened random, however almost never when the fuel tank was completely full. I searched a longtime for the possible cause (glowplugs, fuelfilter, fuelinjectors) without finding the solution.
A few months ago I cleaned out the fuel-sender-unit and the fuel-line (running from the fuel-sender-unit to the fuelfilter) with compressed air. That solved the starting problem. Since then the car starts again without any problem.
The removal of the fuel-sender-unit is a bit tricky. I cut a circular hole just above the unit with a pair of sheet-metal shears. Otherwise you have to remove the fuel tank completely, what is quite difficult to do without a lift bridge.
 Report this tutorial
0 Comments
