• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Guide to swapping a Focus MK2 Radio for a MK2.5 Radio
1 Comment
Hi, I have a 2007 (pre facelift) Focus Titanium with the older Sony head unit, and was just wondering, apart from the looks, if there are any other advantages of replacing it with the newer Sony unit? Can’t really fault the original Sony unit as a factory fitted set. But at some point may consider fitting Focal component speakers, and if this makes a noticeable difference without fitting an expensive aftermarket head unit, I may consider trying the more modern Sony unit if there are any Sound quality/performance advantages.
Share this comment
Link to comment
