• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
Fitting Blue Illuminated Window/Window Heater Switches
After recently changing my window/window heater switches from standard green to blue illumination I thought i would do a quick guide on how to swap them over.
Use your electricians screwdriver to prise the heater switch out from its housing in the following positions:
tutorials-37948-0-68247300-1368551064_th
tutorials-37948-0-26119700-1368551096_th
You then can pull the switch from the housing to unplug from the wiring which can be done by pushing the small release button hilighted in red in the following picture:
tutorials-37948-0-38064500-1368551282_th
You simply then plug the new switch in and push it back into position and you have the following:
tutorials-37948-0-81870300-1368551508_th
You can see the original colour of the switch if you look at the heater control panel below:
tutorials-37948-0-15902700-1368551578_th
Window Control Switches
To remove the window switches again use your electricians screwdriver to prise the window switch out of its housing, I would recommend using a cloth to protect the plastic edge where you dig your screw driver in or you'll end up marking it slightly as you can see I have :lol:
tutorials-37948-0-10578800-1368551737_th
It is quite difficult to remove the switches but stick at it and you'll soon have them out. You then have the following:
tutorials-37948-0-50893700-1368553087_th
tutorials-37948-0-20241900-1368551951_th
Note the red circle hilighting the push button to release the first plug from the switch (drivers side has 2 plugs/passenger side has one) remove this plug first of all then this allows access to the push button the release the second plug hilighted below:
tutorials-37948-0-73416000-1368552962_th
Once both plugs are disconnected, simply plug in your new switch and pop the switch back into its housing.
As stated earlier the passenger side switch only has one plug to disconnect:
tutorials-37948-0-43784700-1368553176_th
The switch is removed in exactly the same way as the drivers side switch.
Once both switches are in you have this:
tutorials-37948-0-33452400-1368553307_th
tutorials-37948-0-16952600-1368553336_th
tutorials-37948-0-13178800-1368553388_th
I bought the blue illuminated switches from ebay but if you're handy with soldering its realy easy to take this switches apart and change the LED to a blue one.
I ALSO HAVE THE BLUE ILLUMINATED HEADLIGHT SWITCH AND WILL BE UPDATING THIS GUIDE TO INCLUDE HOW TO CHANGE THAT WHEN I HAVE FITTED MY FRONT FOGLIGHTS AS I HAVE GOT THE HEADLIGHT SWITCH WITH THE ADDITIONAL FRONT FOG LIGHT OPTION. I'M ALSO GOING TO ATTEMPT TO CHANGE THE HEATER CONTROL PANEL TO BLUE ALSO ALTHOUGH I'M NOT SURE IF THIS IS POSSIBLE.
Why not check out my guide to change your speedo illumination colour also: http://www.fordownersclub.com/forums/tutorials/article/41-fitting-a-lockwood-dial-kit-fiesta-mk-6/
Thanks for reading my guide hopefully its usefull to someone.
 Report this tutorial
1 Comment
PLEASE BE AWARE THE WINDOW SWITCHES FOR THE MK6 AND MK6.5(FACELIFT) ARE SLIGHTLY DIFFERENT SO IF YOU PURCHASE THEM ONLINE BEWARE YOU ARE GETTING THE CORRECT SWITCHES FOR YOUR CAR. ALTHOUGH THEY LOOK THE SAME APPARENTLY THE FACELIFT SWITCHES HAVE DIFFERENT CONNECTOR PLUGS
Share this comment
Link to comment
