• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
Cabin/Interior pollen filter change Fusion 1.4 TDCI
Description
Guide is for a LHD drive by wire car but also applicable to a RHD car.
On the mainland it's accessible from the drivers side, guess on the islands it will be on the passengerside ^_^ .
1) First remove the "Philipsscrew" holding the panel at the side of the middle console. You can turn it a few threads out and then pull the whole screw/clip out. Now remove the panel, the only thing holding it in place are 2 clips opposite the screw so just pull.
(Sorry, no pics :( )
2) If you have a LHD car then you now first have to remove you're throttle pedal. If you have a RHD car you can skip this step, assuming it's on the passengers side.
Pedal is mounted with three 10 mm nuts. Remove the nuts, pull the pedal towards you and unplug the plug.
tutorials-44148-0-61425400-1373544552_th
3) Now you see a cover which is hold done by 4 screws with Torx heads. Remove all 4 screws.
tutorials-44148-0-86511300-1373544531_th
4) Remove the cover, it will just come of or even fall off.
5) You now see the side of the filter, just pull it out. Now look/feel if the bottom of the slot is clean, no branches/leafs/etc.
tutorials-44148-0-84426400-1373544517_th
6) Take you're new filter and look at the top to see if the arrows point in the direction of the gearshifter. Now slide the new filter in.
tutorials-44148-0-06218200-1373544482_th
tutorials-44148-0-13659400-1373544456_th
7) Put the cover back and put the 4 Torx screws back in and tighten them. Only gently, it's just plastic there in!
8) Click the side panel back in and just push the "Philipsscrew" clip back in.
9) Put back the throttle pedal bij fastening the three 10 mm nuts and reattaching the plug.
10) You're done, don't know what the replace interval is of the cabin filter but you should be good for a long time :)
The filter that i removed was about half the thickness of the after market one i put in. The slot is the same thickness as the after market filter so i don't know why the original one was just half the thickness. Ford moves in mysterious ways ;)
tutorials-44148-0-25189600-1373544503_th
 Report this tutorial
0 Comments
