Sign in to follow this
Followers 0
Fitting / Replacing leather gearshift surround / gaiter on Mk3 Mondeo
Description
How to fit a leather gaiter surround on Mk3 Mondeo - May apply to other fords - Focus / Fiesta etc
I thought my gearshift gaiter was looking a bit scabby -
tutorials-38050-0-84689400-1377057788_th
So i bought a Genuine leather gearshift gaiter, i went for the black leather with black stitching, but other colours are available -
tutorials-38050-0-99883000-1377057830_th
Ist i unscrewed the gearknob -
tutorials-38050-0-27434900-1377057880_th
Then the trim lifts from the back with the screwdriver (carefully)-
tutorials-38050-0-55819900-1377057976_th
the gaiter and surround then comes away from the console plate - then the trim has to be seperated from the trim (careful - its delicate) i used pliers and scissors -
tutorials-38050-0-25477800-1377058086_th
Once the remnants of the old gaiter are removed - I lined up the new one -
tutorials-38050-0-85541400-1377058466_th
I then carefully hooked the new gaiter onto the back of the console plate -
tutorials-38050-0-05438800-1377058627_th
The trim then gets fitted onto the bottom -
tutorials-38050-0-12849100-1377058715_th
I used superglue for this - i recommend you take it away from the car, wear gloves, put lots of newspaper down/ mask everything if you use superglue
The plate/ new gaiter and the gearstick gets fitted back on -
- finished! -
tutorials-38050-0-00020600-1377058990_th
georgen and mixmasterlooney like this
0 Comments
