• Announcements
    • Stoney871
      Posting in General Chat thread.   11/11/2017
      it has been noted that too many Members are posting messages in the General Chat area instead of the correct Forums. Any messages posted in the General Chat area that are not General Chat will be deleted without warning and offenders may recieve warning points if repeated instances are seen from that Member. There are plenty of different Club areas that encompass 99% of Ford related posts, please select and use the correct one. If anyone is not sure of which area to post something then feel free to P/M myself or other Senior Staff for guidance. The Moderating Staff are having to spend far too much time chasing this problem instead of maintaining the other areas of the forum.
Sign in to follow this
Guide To Fitting Additional Boot Light In Ford Focus Mk2 And Mk2.5 (Part 5)
Description
And Other Models like Fiesta too.
Another Very Important part at the end, to prevet you boot from leaking, ensure the rubber seal is overlapint the trim allaround the door, if it's not just pull with your fingers till it overlaps again like it should.
A quick Hoover of the boot to remove cable remains and replace spare tyre etc.
One Last press around the rubber seal prior to closing the boot down ensuring the rubber is flapped over the trim all around,
And thats it.
I hope this guide is Useful to other ford owners and thanks for reading.
Check my signature at the bottom of my posts for a list of Guides I've made.
 Report this tutorial
0 Comments
