Sign in to follow this
Followers 0
How To Replace the Third Brake Light on a Ford S-Max
Description
The video above shows the locations of the trim and the clips underneath.
Carefully prise off the trim inside the boot lid. You can then access the clips. Push both of these toward the centre to allow the light unit to be removed.
This then allows straight forward replacement of the bulb.
0 Comments
