Member Since 02 Jun 2008
Offline Last Active Aug 10 2008 08:33 PM
02 June 2008 - 05:02 PM
in the head there are two things 1st there is the remote that operates the doors (deadlocks & sets alarm) which the car can program by the handbook. Secondly there is the transponder which is activated as you turn on the ignition . The in board management system sends a signal via a coil on the steering column to the key and then the transponder returns a coded signal if it is the wrong one it shuts the car down (it is inductionally coupled so no batterys are requied) These the car cannot programe with only one key (red chip requires red master - blue chip requires two working keys).When you have only one key the dealer has to program the new key into the management system or you have to find a key cutter that can clone another.
Regards ian
In Topic: new key for focus
02 June 2008 - 04:26 PM
Hi they do not make one for this model. fegards ian
02 June 2008 - 04:23 PM
Hi there,
I need a new key made up for my Ford Focus and asked my local dealer for a flip style one, they tell me that I can't have this type of key for my car due to its version or model or something, is this likely to be true for any technical reason?
My car is a 2006 (56) Ford Focus Sport 5Dr, 1.8 TDCi Duratorq
Many thanks in advance for your help.
