RickyBobby
Member Since 24 Nov 2009
Offline Last Active Jul 26 2010 12:57 PM
In Topic: Rear Mudflap Fitting
29 April 2010 - 12:22 PM
Very easy to fit, just require patience.  I put ford ones on the front and back of my car in the dark with no experience so you should be fine!  Instructions come in the packaging and are pretty clear.  Plastic clips you have to remove to fit the flaps are a complete b*****d though.
EDIT: No need to remove road wheel btw, there is enough room for manoeuvre.
In Topic: Matt Black Vinyl Wrap!
29 April 2010 - 12:18 PM
Would love to see how it looked! I'd never have the patience
In Topic: How Easy Is It To Change Break Pads And Discs
23 April 2010 - 08:33 AM
I changed my own on my last car and it was a relatively simple job. There are some clips from memory (was a couple of years ago) which were a pain to get off but managed it all with a basic tool set and the special "ford" allen key. you will need to buy that allen key specifically, i bought 3 different sets before i found i could only get it on its own.
In Topic: Mk7 Heated Windscreen
20 April 2010 - 01:05 PM
They did the heated screen in my last fiesta too with that resin.  Was still fine afterwards!
In Topic: How Do I Activate Auto Door Locking And Unlocking Drivers Door Only
19 April 2010 - 12:03 PM
This post seems to have all the info:
http://www.fordowner...indpost&p=39612
Extract:
"Anti Hijack Feature
1. Turn on ignition until the dash lights come on but don't start engine!
2. Lock the door using the lever on the door handle and then unlock 3 Times
3. Turn off ignition
4. Repeat 2 but with ignition OFF
5. Turn on ignition - should hear a beep
6. Lock door again as in 2 BUT ONLY ONCE - final beep should be heard
7. Done!
Doors should now lock at around 5mph. including reverse!!!"
Don't know if any of it works though, have only attempted the drivers door one in the previous posts.
