I've had my 2005 Fiesta for about 4 months now and there appears to a problem with the brakes that has been getting worse the longer I have had the car. The problem is that when I brake from anything over 35mph a get a serious vibration through the steering wheel with an intermittent grinding noise coming from the front right of the car. The heaviest vibration comes whilst braking from 45-35mph.
When I bought the car, everything was fine however about a month later the intermittent grinding noise from the front appeared. I took it to the garage thinking that it was probably the pads/discs at fault, however, they said everything was fine and the only problem they saw was that it could have been caused by the cheap brake pads. (By the way, this garage wasn't the one where I bought the car from.) Two months later after going to the garage the vibration from the right started.
I'm ruling out any problem with the steering rack as there is absolutely no vibration in the steering wheel at any other time even at high speeds of 70mph. The vibration is only there when braking.
I'm thinking of taking the car to a garage to get the pads and discs replaced, I just wanted to know if anyone on this forum knew of the problem and any possible solutions. I still think it's one of the discs that have warped.
Max
Member Since 05 Jun 2008Offline Last Active May 10 2009 06:19 AM
Find content
Not Telling
Latest Comments
More
