leech533
Member Since 08 Jun 2008
Offline Last Active Aug 21 2008 09:27 AM
In Topic: Ford Focus 2000 X Reg rear passenger footwell wet!
21 August 2008 - 09:22 AM
just thought about what mintalkin has said. Even if it was the pollen filter and the car is parked on a gradient then the front passenger footwell would be wet wouldn't it? but its completely dry???
21 August 2008 - 09:10 AM
the most common problem is the pollen filter cover which lets water into the passenger side footwell if your car was parked on a gradient it could run to the rear,Check the bottom of the windscreen. The filter cover forms part of the windscreen seal - on the passenger side. The cabin air intake is under
the cover.if this seams ok it could be the plastic weather seal behind the door panel damaged or the door seal itself
thanks mintalkin, the car is the garage this morning for something else but i will check this when i get it back this afternoon.
In Topic: Engine Management Light
08 June 2008 - 06:46 PM
I would reset the ECU first by disconnecting battery for 10 mins
see if it comes up again.
Cheers Steve, Wife has car out tonight will try tomorrow and let you know!
08 June 2008 - 06:44 PM
