whisky
Member Since 12 Dec 2009
Offline Last Active Apr 26 2015 09:17 PM
In Topic: Focus Mk2.5 Headlight Beam Pattern Issue!!
22 March 2015 - 05:22 PM
Thanks I will give it a try when darker.
22 March 2015 - 04:23 PM
I have a similar problem but only became noticeable when I replace the two head light bulbs for some Osama night vision lamps.
The pattern from the beam seems very close and low and not projecting far forward. The levelling motors seem to work ok and do adjust if I move the rotary switch within the car. It's as if they need to be lifted up somehow to allow the beam to be throne forward.
In Topic: Anyone Retrofitted Power Fold Mirrors?
11 October 2014 - 06:10 PM
I had to order the new window switch part in through local ford dealer it arrived from Germany in about 3days then swapped it over with existing fitted part, then as already said only had one wire to install simple job.
