delboy
Member Since 14 Jun 2008
Offline Last Active Apr 27 2013 06:03 PM
In Topic: Car Making A Thudding Sound
27 April 2013 - 06:05 PM
if the garage done any work atall to the car & it came back to you with the noise after they messed with it i would make sure they fix it pronto and would not wait a week or 2 and hope it goes away. man up & get the muppets at the garage to sort it if they caused it
In Topic: Blown Bulbs & Faulty Wireing?
25 March 2013 - 09:19 PM
thats what i said hubby1959
25 March 2013 - 05:14 PM
sounds like you need to take out the bulb holder & disconnect the wire plug as they sometimes gum up and also check the bulb contacts as they degrade with age and damp.
i usually apply wd40 on all of the connections and make sure the contacts are clean. then refit bulbs etc and try the lights.
In Topic: Console Lights & Worn Out Brake Pads
06 March 2013 - 06:28 AM
brake shoes/pads wear depending on the type of driving. town or city driving will wear them down quick.
i get about 28 months out of mine on the fronts then about 36 months rear there abouts.its down to all the stop starts
for lights etc so 2 yrs on the pads is about usual i recon.try your local halford service center as they do them for life.
so you pay once & they wear out they do them for nothing next time.
In Topic: Engine Issues
11 January 2013 - 07:01 AM
have you serviced it & changed the fuel filter as i done my sons fuel filter a while back & it's made hell of a diffrence
from memory there is no electrics that would effect the engine or no electrics atall by the filler cap or that area.
seems more a coincidence.
