Member Since 15 Jun 2008
Offline Last Active May 23 2009 09:05 PM
In Topic: ford fusion 1.4tdci 2003 full service
22 May 2009 - 03:17 PM
A major service should be carried out every 3years or 37.5k miles
With your car being roughly 6 years old it should be getting its second major.
You will need 5w30 semi synthetic oil (fully synthetic can be used but is more expensive) an oil filter, air filter, fuel filter and a pollen filter
It will take roughy 3.8 litres of oil.
Thanks folks for the help and advice its much appreciated ;)
In Topic: Mk4 Lumpy Under Acceleration
19 June 2008 - 11:33 AM
thinking about it if one went then it would be rough as you would have a cylinder down... so try the distributor cap, rotar arm inside.
I am taking a guess though.
Also check the lead from the coil to the distributor.
If its a zetec it will have a coil pack not distributor.
In Topic: Mk 4 Ford Fiesta
16 June 2008 - 02:54 PM
hi ive recently bought a mk 4 Fiesta 1.25 Zetec. Its a 4 door
any ideas on wat cheap and easy mods i can do to it, to make it look better as it is a 4 door..
Hi Gallagher, are you looking to modify engine or are you talking purely cosmetic? <_<
