Support the club!
james_60
Member Since 01 Jan 2010
Offline Last Active May 14 2013 09:07 PM
Starter Motor Wiring Diagram Or Photo Even Better
10 May 2013 - 06:52 PM
Hi
Iam having trouble with the starter motor on my escort
A wire fell off and now the starter motor does nothing.
Can someone supply a picture of the wires attached to there starter motor (petrol engine preffered)
My car is a 83 1.6 ghia
Jamie
Just Bought An 83 1.6 Cvh Ghia It Will Not Run Properly Plz Help
01 May 2013 - 08:59 PM
Hey dudes
I have just bought a 1983 Ford Escort 1.6 Ghia
It idles fine but as soon as you rev it etc it pops back through the carb
The Dizzy cap and rotor arm have been changed because it would not start at all with the old bits.
plz help
Jamie
How Often Do You Check Your Car Before Starting A Journey
27 March 2013 - 08:34 PM
Hi Folks
Basic Checks Are Often Being Forgotten Due To Being Late Or Being In A Rush Etc Etc
Suprisingly They Only Take A Few Minutes But Could Save:- Someones Life, A Fixed Penalty Fine/Court Appearance/Lost Licence
1. Always Check The Oil Level
It Is Suprising How Often We Forget This One Despite It Being A Vital Engine Fluid.
Usualy If Your Oil Is On The Minimum Level It Takes One (1) Litre To Top It Back Up To The Max Mark.
When Your Oil Level Starts Getting Lower Than This Vital Components In The Cars Engine Can Start To Overheat Or Rub Together And Cause Wear At A Greater Rate Than Acceptable. A Litre Of Oil Can Cost Between £3-20 A New Engine Anything Up To £5000
2. Bulbs
A Failure Of Just One Main Bulb Can Cause An Accident. Failed Indicators/Brake Lights/HeadLights Can Confuse Other Road Users, Fail To Warn Other Drivers, A Good Quality Bulb Can Be Bought From £1 Right up to £20 Always Change Them In Pairs Because If One Has Failed The Other Is Likely To Pop Pretty Soon, A Bulb Failure Can Attract A Fixed Penalty Fine and Points Right Up To Loss Of Your Licence If You Knock Someone Down Through Not Being Able To See The Person/s
3 Tyres
These Often Get Overlooked To The Extent That They Never Get Inflated Between Services (I have Seen This Myself Through Working At A Garage) Low Tyre Pressures Can Cause :- Increased Wear/Longer Stopping Distances/Higher Fuel Consumption
Always Check The Tyre Pressure At Least Once A Month Or When Refueling. It Could Save You Hundreds.
And Always Check Your Tread Depth 1.6MM Is The Legal Limit over 3/4 of the tread, Insist On Changing Tyres when they reach  2mm if you travel Long Distances.
Worn Tyres Can Also Cause Greater Stopping Distances/They Can Cause You To Slip Easier Due to Less Tread And Your Are At A Greater Risk Of An Accident With Worn/Bald Tyres Plus You Will Attract a Fixed penalty fine and Points On your Licence or Worse Still An Accident.
The Amount of cars that I have seen with one bulb blown is shocking !!!
Jamie
Ordered My New Focus Titanium X :-)
14 March 2013 - 10:10 PM
Hi Dudes and Dudettes
I havent been online lately due to ill health :-(
I have been Awarded Higher Rate Mobility on my Disability Living Allowance,
So I went down to my fav ford dealer Vospers In Marsh Mills Plymouth And Placed An Order For :-
Ford Focus
Titanium X
1.6 TDCI 115
Ink Blue
Plus the following options
Appearance Pack (Keyless Entry/Dark Tint Rear Windows)
18" Alloy Wheels (5 Spoke)
Sony Premium Sound System With 10 speakers
Door Edge Protectors
Diamondbrite paint treatment
Iam really excited :-)
The car will be a factory order and is supposed to arrive at the dealer in mid may but we will see
Let me know what u think
Jamie xx
What Does Dtc 90Bd13 Relate To (2012 1.6Tdci Zetec)
10 February 2013 - 09:40 PM
Hi Folks
What Does DTC 90BD13 Relate to (2012 1.6tdci zetec)
It is on the Radio Screen when i put it into diagnostic mode
Jamie
