j harvz
Member Since 18 Jan 2010
Offline Last Active Jun 23 2010 05:01 PM
In Topic: Ford Focus
21 June 2010 - 09:25 PM
I had to buy one for my mk1 focus. I bought the fob + blank blade from ebay for about £40, Paid Ford £12 odd to cut the blade but still need someone to have it programmed to the immobiliser to allow it to start the car, Ford quoted me 120 odd quid, No thanks!
have you try'd program my fob i did mine off there also did one for a golf
In Topic: Low Idle On 1.6
16 March 2010 - 08:41 PM
It is on the 1.8 havent done a 1.6 but i assume its the same location look at the car from the front lean over into the bay and look down the side of the throttle body housing youll see this [attachment=1340:!BnL-RLQCGk~$(KGrHqYH-DgEttbk28UTBLikQtd)q!~~_12.jpg] this is the idle control valve 2 bolts hold it in place you can either access from above or from under the car i would also check the emission hose on the car it looks like this [attachment=1341:DSCF2412.JPG] thats the part number on it its below the throttle body with the engine running you maty find this has collapsed
cheers fella will be doing that this weekend then. i had checked the pipe before it is fine.
16 March 2010 - 08:04 PM
thanks guys now is it a easy job to do???
