jocojohn
Member Since 23 Jun 2008
Offline Last Active Feb 23 2013 04:40 PM
In Topic: Brakes Problem
20 February 2013 - 11:17 PM
Hi, there is a tool you can buy, only 2 or 3 pounds, I think from Wilco or similar, its a small cube with pins on each face that fits into the slots in the brake piston, this attaches to a normal socket wrench and makes winding back the piston quick and easy. Because the pins on each face are spaced slightly differently this tool can be used on different types of car. It worked a treat on my mondeo without the need of removing the caliper.
John
In Topic: Mk3 Mondeo Estate Rear Bearing Replacement Urgent
14 February 2013 - 11:20 AM
Hi, my rear bearing went recently on my 52 plate mondeo saloon, dont know if the bearing differs on estates, but I found a site on ebay that only cost about £29 for a new bearing and about £4 postage.
John
In Topic: Mondeo Misfire
27 November 2012 - 10:42 AM
Just an update, tried a new coil pack and all is well.
thanks for the input Peter,
John
In Topic: Clicking / Knocking Noise
25 September 2012 - 10:58 AM
Hi again, does anyone know if its ok to run the engine for a short while with the aux belt removed, or is it possible to damage the ecu or cause other problems.
thanks, John
In Topic: Ford Focus Windscreen Wiper Problem
13 September 2012 - 11:03 PM
Hi, Have you checked the wiper linkage? both my sons have focus,s and have had the same problem with the ball and socket parting company, if you can hear the motor turning this will be the problem, John
