Member Since 26 Jun 2008
Offline Last Active Apr 08 2009 11:35 AM
temp/petrol gauge
07 September 2008 - 04:48 PM
hi,can anyone help when car is turned off temp gauge and fuel gauge both go to the 12 o-clock position,anyone have any ideas everything else works ok.thanks
engine removal
29 August 2008 - 04:03 PM
hi everyone,changing engine on a 1.6,haynes says engine and box are to be removed as one unit,lowered down and taken out from under the car.does anyone know if it is possible to remove engine only upwards.thanks for any help.
cooling system
10 July 2008 - 07:29 PM
hi everyone
can any one help have a focus 1.6 zetec,when running water is boiling and filling up expansion tank,temp gauge going to 12 o-clock,put in new cht sensor,thermostat,had test for blown headgasket and flow check on radiator,both ok,removed water pump and is ok,removed all hoses,no blockages.totaly stumped can anyone help please.
thanks paul
26 June 2008 - 10:05 AM
hi,can anyone help me,have a 1.6 zetec 3 door ,coolant is bubbling in header tank and cooling fan is not cutting in,but both fans work when ac is switched on,checked fuses,changed relay.was told it could be fan sensor if so were is this situated.thanks for any help.when ac switched on coolant stops bubbling in header tank.
