Sam Magee
Member Since 27 Jun 2008
Offline Last Active Sep 23 2009 10:53 PM
In Topic: 0-60 in 40 seconds!
01 August 2008 - 06:00 AM
Come on, we all know that's a filthy lie.
Ur right by the days before the back box got replaced it was 0-60 in well............. never it only got to 58mph!
Has been working well for a while now.
Cheers again.
02 July 2008 - 05:08 AM
HIM8
TRY THE FOLLOWING
HIT THE EXHAUST NEAR THE MIDDLE TO FRONT WITH A HAMMER
AS THAT SHOULD FREE ANYTHING THAT'S BLOCKING THE THING
USUALLY YOU CAN HEAR IT IF YOU HIT IT HARD
I DONE THIS ON A FORD ESCORT I HAD AS THE CAT BROKE DOWN INSIDE
& BLOCKED THE EXHAUST.
CHANGED IT & ALL WAS FINE
I FORGOT THAT BIT M8
Hi delboy,
A new back box has revitalised the car. 0-60 is now 13 seconds which is better than the rated 13.9!
You are quite right the exhaust was blocked and was causing the performance issue. Replacing the oil and oil filter was greatly needed as there is a distinct differance in what came out to what went back in and this has completly stopped that worrying noise comming from the higher rev ranges in the engine.
Thanks for your help, it has been very much appreciated.
Cheers,
Sam
29 June 2008 - 09:53 PM
hi sam
is the clutch ok on the car & the gear box ?
it maywell be a clutch slipping ?
The clutch and gear box feel/sound ok. In fact the car all be it slow is ok for about a mile or two once it is started.
Whilst test driving it today I had to pull over as with 'foot through the carpet' in first gear the car was really struggeling to make it much over 10 mph. I thought the engine was seizing but already confirmed that the oil level was fine.
After a 10 min rest the car was once again moving (all be it giving me only around 12 mph per gear) for about a mile or two.
A friend has suggested that there might be a blockage in the cat or the exhaust system. Now that we know that the air/fuel going in is good there might be something stopping the exhause fumes from comming out.
I'm taking the KA to be tested at my local kwik fit tomorrow at lunch. And will post the results tomorrow.
Cheers,
Sam
28 June 2008 - 10:08 PM
1ST OFF I WOULD TRY THE FOLLOWING
NEW PLUGS
AIR FILTER
OIL CHANGE & FILTER
IT COULD BE
A BLOCKED PETROL FILTER
THIS IS LOCATED ON THE PASSENGERS SIDE NEAR THE TANK
EASY TO REPALCE
IT COULD ALSO BE 1 OF THE FOLLOWING
FAULTY FUEL PUMP OR LOW DELIVERY PRESSURE
WORN CYLINDER
ALSO CHECK THE THROTTLE BODY FOR LEAKS AS THIS CAN CAUSE IT &
CHECK THE HOSES THAT FIT ONTO IT
BLOCKED INJECTORS
BUY SOME LUBE TO CLEAR THE INJECTORS THAT YOU ADD WITH THE PETROL (RED-X) MAYBE
THE NOISE YOU SAY YOU HAVE MAYBE
HAVE THE CAR HAD A TIMING CHAIN DONE RECENTLY AS THAT MAY CAUSE IT IF IT'S NOT BEEN
FITTED CORRECTLY
CAN YOU TELL ME HOW LONG IT'S BEEN HAPPENING ?
I WOULD DEFO TRY
PLUGS & FILTERS 1ST
TRY DRIVING IT WITHOUT THE AIR FILTER ON THEN SEE IF IT'S ANY DIFFTENT ?
LET ME KNOW MORE IF POSS M8
Thanks for your quick response.
The problems be going on for about a week/week and a half now. I haven't had the car serviced by anyone since Feb but so I don't think anyone has played with the timing since then. I have however replaced the following today as suggested.
>Air filters (Large yellow one and small blue sponge)
>Oil filter
>Oil (3.25 liters of 5w-30)
>Petrol filter
>Spark plugs
>Put in a bottle of REDEX equivilant in the petrol tank (I could only find one injector cleaner but a dozen differant types of fresh cake at my local BP!).
>Oh and the rear windscreen wiper blade ;-)
The car now seems to strugle to top 50 mph. Doh! I can't tell if the sound has gone because it won't get up to speed. I will have a test drive on the M25 tomorrow.
I keep checking the oil level but am finding it a little hard to tell what the level is as the oil is so transparent compaired to the near black stuff that came out of the sump (I'm guessing this is a good thing).
I put in the 3.25 liters of oil as I believe is recommended in the owners manual. My best guess is that the oil level is slightly too high but I'm going to have another look tomorrow when it's light.
Yesterday I tried driving without the air filter and then without the air mass flow meter attached but the car performed the same as with them both plugged in.
If you have some more ideas of things that I can check I would appreciate it.
I will post back the results of my road test tomorrow.
Cheers,
Sam
