ZeEscort
Member Since 03 Feb 2010
Offline Last Active Mar 31 2015 07:59 PM
Key Cutting Code
24 January 2015 - 12:10 PM
Where would I find the code for a key cutter, as my key for car is so beyond recognition they can't copy & cut so they require the code for the key to make a replacement.
All help appreciated.
Replacement Key
09 December 2014 - 08:44 AM
I swear this car just hates me right now.
Besides going to Ford, who rip the hell out of you in terms of ££££ to replace.
Anyone know of any good reliable place, that I can get a replacement key from (that doesn't cost the earth). I've found mine has become heavily worn around the middle to base of the key and so now struggling to open the steering lock.
Loss Of Power
18 October 2014 - 10:27 AM
Ok here I am once again, with some more woes of the Mondeo.
So the car went through MoT, but since the MoT I've noticed an issue with performance. Now normally when I hit the high rev range, from 1st through to 3rd I can feel the toque in ranges of 3000 - 5000 and can feel the pull. However in the last couple of days, I've seemed to have lost that toque. I'm at a loss at what it could possibly be and so many thing are running through my head of possibilities that all I'm now seeing is £££££££.
So some of the things that I think it is.
Clutch:
I'm not noticing any slipping with the clutch, or drop downs in power (though on occasion it does a little spit in 3rd).
Gearbox:
Nothing noticeable from the gearbox, it does have a little left/right shake but it's not dropping out of gear or grinding.
Exhaust:
I do have some damage to the exhaust, the sleeve on first section from manifold is not holding in place (Noticed this before MoT). I've not fully checked the exhaust since, but I do get a rattle from it on backend more than what I should do.
The only other thing I can hazard a guess at, are things like fuel filter, air filters, injectors and other bits.
Anyone else have any input to what could be causing the issue?
All the help is appreciated.
As an after thought, I did recently have to top the oil up from almost empty and it's played up since......
Thank You To All
25 September 2014 - 02:56 PM
Just wanted to say a big thank you, to everyone who has helped with advice and other things.
The car went through the MOT today, after having a huge amount of money spent on it to get it fixed.
So thank you to all those who helped me on my way.
Making Brake Line.
16 September 2014 - 02:20 PM
I'm in the middle of trying to sort out my break lines, as I have various section that are very corroded. I've got 3/16 copper brake line to replace the damaged section, flare kit to create the lines and M/F metric unions.
I've been practising flaring the pipe, which I can do really well, especially on a double flare.
But the union doesn't seem right to me, can someone advise from the images that I am connecting the union correctly and will hold if it's done this way for the breaks.
Cheers.
