Member Since 10 Feb 2010
Offline Last Active Apr 01 2015 02:53 PM
Thermostat Housing Bolts
30 March 2015 - 11:06 AM
Hi all,
Two of the bolts for the thermostat housing on my ford focus (2001 1.6 petrol) has snapped
off; the head part broken off. I have got replacement bolts to replace them. But
can anyone give me advice on how I can remove/extract the two broken ones, it
is tight and difficult area to work on.. so any advice tips would be greatly appreciated?
Thanks in advance.
Idle Revs Issue
02 March 2015 - 05:40 PM
HI all, i am having some issues with the idle rev on my focus which is  a 2001 1.6 manual petrol model.
When I am driving and come to a stop I put the car into neutral, the revs jump up to 2000-2100rpm and stay there for about 2 to 3 secs before dropping to about 1000rpm - my feet are off all the pedals. When i am in gear and driving the revs seems to be fine/normal - go into gear the revs are normal.
Does anyone know what could be causing this, what do i need to look at?
Thanks in advance guys.
Oil Around Spark Plugs..
19 January 2015 - 02:09 PM
Hi all, I changed the spark plugs this weekend on my car and notice that around two of the spark plugs there was some oil, looked like engine oil. I am guessing that some kind of seal/gasket needs replacing, can anyone tell mewhich gasket/seal it is that I need to replace please and also whether it is
something that you could easily do yourself?. I mopped up all the oil that was there before putting the new plugs in.
Also the boot release/open button on the dashboard seems to only work intermittently, anyone know how to cure this too please?
My car is 2001 mk1 1.6 focus, thanks in advance guys :)
A Few Niggling Problems.
23 June 2014 - 04:15 PM
Hi all..
I am having a few niggling problems with my 2001 focus.
First is that the front passenger electric window, goes down without any problems.. but when i comes to putting it back up (closing) it struggles to go up/close.. comes up very slowly.. you can hear it struggling. Does anyone know what the cause of it might be? If it was the electric window motor would the open window(window down) function also not be affected?
The second problem is that the front passenger side wheel keeps develeping a bump on the tyre after a while. This is the 3rd tyre that has developed a bump on the tyre. It is causing the steering wheel to wobble as i drive. Braking is not affected nor is the car pulling to one side. I have checked that the tyre is not catching on the wheel arch lining or anything. What else could i check/be causing the tyre to develope a bump?
Thanks in advance guys :)
