click cluck
Member Since 06 Mar 2010
Offline Last Active Aug 01 2012 09:54 PM
In Topic: Ford Mondeo 2.0 Tdci Dura-Torq Noise
30 July 2012 - 12:47 PM
sounds like (!!) the tensioner pulley and or crank - classic symptom = noisier when air con is on.
ok to leave - just put up with noise - mind you if bushes are / have failed I suppose eventually something will break!! but not urgent
In Topic: Mondeo Mk4 Tdci Turbo Failed??
29 May 2012 - 03:55 PM
http://www.talkford....ttach_id=118611
PHOTO OF LABELLED ENGINE PARTS...
29 May 2012 - 03:53 PM
EGR valve is bottom left - follow the pipe work from turbo to intercooler ( under rad ) and up to EGR - two pipes go to it - one from intercooler ( fresh air from Turbo ) and another smaller metal one crosses in front of manifold ( from exhaust )
You will need a good too set to get all the nuts off!!!
Just done mine - clogged up with gunge ( 50% restricted ) mad no difference
Blanked off - no difference
Symptoms - flashing heater , loss of power and fault 2263 - turbo pressure.
Now taken off actuator and awaiting diagnosis...
drives the same - no power / turbo!!
