Member Since 15 Mar 2010
Offline Last Active Mar 24 2010 02:01 PM
In Topic: Noisy, Smelly Cat On Focus St170
17 March 2010 - 03:30 PM
Doesn't the CAT have a 60k mile guarantee or ten years? Says something in the manual.
Probably does, mine's done 105,000! Oops! I have pretty much rebuilt this car since buying it nearly 2 years ago, fingers crossed this will be the last repair for a while!
17 March 2010 - 03:29 PM
ford always over price theyre parts you could firt a sports cat http://www.europerfo...;sub_category=1 or a lot cheaper http://cgi.ebay.co.u...=item1c0bce75d1
Brill, thanks, the ebay one is the exact one I'm looking at
In Topic: Focus Dashboard Secret (Trick)
17 March 2010 - 03:23 PM
This trick can be found on www.fordst170.co.uk and it does work:
Self Diagnostics Mode
The Self Diagnostics Mode gives you in-depth information about your engine and the actual numbers in digital. To use it, follow the steps:
* Insert Key but do not turn it on
* Press and hold the Trip Meter Reset Button
* While holding the reset button, start your car and continue holding the button
* Within 10 seconds, the display should change to "test" in LCD font and the needles will do a full sweeping. Release the Button
Pressing the button will now cycle through some 17 different modes
* 1.Shows a Gauge Sweep
* 2. Shows all 8's on the LCD (LCD TEST)
* 3. Illuminates all the bulbs on the dash
* 4. Displays hexadecimal value for ROM level
* 5. Displays the hexadecimal value for EE level
* 6. Shows DTC (Diagnostic Trouble Code)
* 7. Digital Speedometer - mph
* 8. Digital Speedometer - kph
* 9. N/A
* 10. Digital tachometer
* 11.Fuel volume
* 12. Engine coolant temperature
* 13. Battery voltage
* 14. ABS fail
* 15. Electronic brake distribution (EBD) failure
* 16. Illumination
* 17. Crank Sense
The listing of the DTC (Diagnostic Trouble Code) from Number 6 above can be found on the DTC Codes page to view the list of codes and its meanings of it.
List of DTC codes can be found here as well: http://www.fordst170...k/dtc-codes.php
