Support the club!
Chase
Member Since 21 Mar 2010
Offline Last Active Mar 04 2013 10:25 PM
In Topic: Ford Fiesta Dvd Gps
08 January 2013 - 10:34 PM
No problem, I'm sure they have improved alot on these units. Just wasn't for me. The sound from all the speakers when watching a Dvd was brilliant.
haigboardman, just a thought. Could it be just the screen not displaying. Do the stereo controls light up when you press the power button? Have you tried to load a cd?
08 January 2013 - 09:28 PM
Sorry haigboardman, the pics don't really help your cause.
I would try for a refund.
Only thing to be careful about is that the supplier might advise professional installation only and require a certificate to say the unit is faulty.
Hope you get it sorted.
08 January 2013 - 09:17 PM
Attached File  SAM_0021.jpg   110.74K   44 downloadsAttached File  SAM_0022.jpg   110.72K   50 downloadsAttached File  SAM_0023.jpg   102.3K   56 downloadsAttached File  SAM_0024.jpg   65.61K   56 downloadsAttached File  SAM_0026.jpg   114.61K   57 downloadsAttached File  SAM_0027.jpg   112.26K   46 downloadsAttached File  SAM_0030.jpg   118.69K   53 downloadsAttached File  SAM_0031.jpg   118.54K   53 downloadsAttached File  SAM_0032.jpg   98.15K   58 downloadsAttached File  SAM_0033.jpg   106.17K   58 downloadsAttached File  SAM_0038.jpg   112.82K   51 downloadsAttached File  SAM_0047.jpg   120.22K   51 downloadsAttached File  SAM_0053.jpg   79.72K   57 downloadsAttached File  SAM_0067.jpg   102.79K   54 downloadsAttached File  SAM_0069.jpg   106.52K   55 downloadsAttached File  SAM_0071.jpg   100.18K   58 downloadsAttached File  SAM_0084.jpg   128.73K   46 downloads
08 January 2013 - 07:34 PM
I bought this unit mainly for the gps and initially I was happy with all the functions. After 6mths of use I couldn't wait to take it out the car.
Jack of all trades, master of none. Just don't expect it to function like a factory fit unit.
The satnav took at least 10 mins to find the satelite and just wasn't reliable.
I had no confidence in the black plastic screen surround and on sunny days was constantly covering it with a towel when leaving the car incase it melted.
The bluetooth quality was terrible. I lost ford voice controls
This was early 2010 so might be improvements now. On my unit I couldn't use steering wheel controls.
The screen was too glaring at night and no dim just the option to turn it off altogether.
The supplied remote control didn't work.
Couldn't get any tv reception at all.
Good points: Sound quality not bad/ Dvd playback and music on SD card worked well.
Fairly easy to install. The amount of cables look daunting but it is just plug and play. I would advise buying some plastic trim removal tools to avoid damaging any trim and disconnect the negative from the battery before doing anything.
The dvd unit is pretty much identical to the ford cd unit so is just a swap. The original screen comes out and the cable connected to it just fixes to the new screen. I can remember the only trouble I had was the sheer amount of wiring and was a bit fiddly to tuck everything in.
I now have a ford mirrornavi fitted which does me fine.
I removed all my original photos on this subject as all my pics now appear on numerous websites of companies who sell the unit claiming the photos to be theirs. They even have the cheek to watermark them.
I will put some up again once I have watermarked them myself.
06 January 2013 - 12:40 PM
It should be pretty much plug and play unless you have a faulty unit. You can't connect the plugs incorrectly. Does your original stereo still work? Might be worth checking the fiesta's fuses before going any further. I fitted mine in 2010 and no longer have the unit now. I disconnected the negative from the cars battery until the unit was fully fitted.
Sorry I can't help more.
