Member Since 30 Apr 2010
Offline Last Active Jun 18 2012 03:31 PM
In Topic: Flashing Glow Plug Light Mondeo 130 Tdci 52
11 June 2012 - 09:11 PM
As above, sounds like a pipe split too me though
In Topic: Coil Light Flashing And Cutting Out
08 June 2012 - 08:24 AM
Seeing as your getting an egr and fueling fault I would suggest the egr to inter cooler boost pipe is split, I would recommend removing it an checking it carefully
In Topic: Rough Idle On A 2004 2.0 Tdci
08 June 2012 - 07:29 AM
I gota take the mondeo up to Lincoln on Saturday lol.
Well I just had a quick butchers, the whole injection loom looks bodged to be honest...
As for the filter well Tge bracket it sits in doesn't join the chassis very well and is very wobbly, hope this isn't an issue.....
On the filter the two single connectors are on there tight but the one with the T-piece bit is loose an wobbly. Is this a common thing?? Or normal?? Should I change it??
Also there is a bit of oil round the crank case breather pipe, will this cause any issues?
I have checked both inter cooler pipes, is there any other boost pipes I need to check hidden around??
In Topic: Ford Modeo Mk 3 Glowplug Light Comes On
07 June 2012 - 07:26 AM
+1 on above
In Topic: How To Clean My Injectors ?
06 June 2012 - 12:25 PM
Was the fuel filter changed with a Bosch, Delphi, ford or motor factor part?
Is there any knocking noises?
Does The roughness go away if you rev a little ?
What's your mileage ect?
