Hi guys, tried disconnecting the 3 wire plug from the alternator but no joy if anything it made it idle worse, got a second had PCM so going to get me mate to key code it tomorrow and give that a try, i'll report back. Cheers for your input
was it just a fault code reader you hooked it up to? these codes may be old ones that were never cleared. clear the codes and check if any new ones appear.
one thing to try, that worked for me although i still havent fixed this issue completely yet either is disconnect the 3 wire plug from the alternator and see what happens. it made mine idle perfectly until i plugged it back in...
Cheers for the reply, no the scanners i've had hooked up to it have been a Launch, Versus and the other was on a laptop by a mate that does scanning and re-programing for a living all 3 scanners came back with missfire on 1 and 3
Latest Comments
More
