Support the club!
Andyzetecs
Member Since 14 May 2010
Offline Last Active Jul 22 2010 11:54 AM
In Topic: What Could Be Wrong?
30 June 2010 - 11:41 AM
Mine does this as well !!
I was told by ford it's because there is no sycromesh on reverse and the gears are straight cut rather then beveled .
They told to just put it in first then into reverse. And if it get so bad it's under warenty anyway. Seems to work ok just when i forget and get the horrid "i'm grinding metal shavings into your gear box noise" :o
In Topic: I Pod
30 June 2010 - 11:33 AM
Hi
Not sure what unit it is but you need to look for the AUX IN  if it has one.
If there is a button on the stereo there will be a 3.5mm socket somewhere for you to connect your ipod to .
In Topic: Mk7 Fiesta With Oz Ultraleggeras
28 June 2010 - 08:07 AM
Nice !
I was thinking of sticking my 17" OZ racing super turismo's on for all those reasons :D
But the street pack ones i have do look nice and far easier to clean than my turismo's !
In Topic: Throttle Body ?
21 June 2010 - 09:29 AM
If i can find one and it's anything like the focus one they are fairly easy to fit, and the ECU's do "learn" so they do adjust themselfs to the extra air and throttle response
Just need to find somewhere that makes or sells them :unsure:
In Topic: Air Con
17 June 2010 - 01:57 PM
All sorted
They had to regas it and seems ok now  :D
