- → Viewing Profile: Posts: itsrelfy
Support the club!
- Group Members
- Active Posts 80
- Profile Views 2,158
- Member Title Settling In Well
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
Ford Model
fiesta mk7
UK/Ireland Location
Kent
In Topic: Snapped Front Coil Spring
16 May 2013 - 12:56 PM
Thanks for the website.
Adrian.
In Topic: Replacing Cooling Fan On Mk7 Fiesta
11 May 2013 - 08:10 PM
The part itself is expensive. 230 quid plus vat from ford just for the part. But I found a good used part on ebay for 70 quid and its perfect. All in all it took about 40 minutes to do.
Regards
Adrian.
In Topic: Hey All New Here And It My First Question.
04 May 2013 - 11:58 AM
I always thought the best way to keep an air con system happy and healthy is to use it as often as possible and once in a while put ya heating up on full for 10 mins so it all gets nice an hot. I assume the air bomb thing would kill any nasties in the system. If your having trouble with moisture check the pollen filter and check all the drainage channels.
I know this probably isn't loads of help but its what I do with mine and ie not really had an issue with any of my cars.
Regards
Adrian.
In Topic: Lumpy, Bumpy Idle On 1.25 Zetec 2009
18 April 2013 - 07:09 PM
Regards Adrian
In Topic: Oil And Filter Change - Petrol 1.4
22 March 2013 - 10:53 PM
I'm intending on having a go at changing the oil and filter on my mk7 1.4 petrol tomorrow, should the weather hold up. I've got all the gear but unfortunately haven't been able to find a suitable guide either on any of the Fiesta-related forums nor on YouTube.
Could anyone assist with the following questions...
- Is the filter reached via the underside of the car or can it be removed through the top of the engine bay?
- Any special tools required to remove/replace the canister filter?
- Is it necessary to replace the sump plug and/or washer during the procedure?
- Is there an undertray present on these, and if so what tools are necessary to remove it?
Thanks!
Hi
I'm not sure that this going to be much help but I saw a chap do a service on a fiesta on 5th gear on Tuesday night. He went underneath to get the filter off. (I should say he had it up on a ramp as he was using a garage where you can rent a ramp and tools)
He said to remove the filter you can use any filter removal tool. There is nothing specific or special that you need. He didn't say about the sump plug or washer but I would fit a new washer just to be safe. And as for the last question. I don't think there is an undertray. Mine doesn't and neither did the one on the tv.
It's worth noting if its still under warranty you need to use genuine ford parts again this was the advice of the chap on 5th gear.
Hopes this helps in some way
Adrian.
- Privacy Policy
Find content
