itsrelfy
Member Since 14 May 2010
Offline Last Active Yesterday, 11:13 AM
#488798 Mk7 Door Rubber Trim Falling Again Any1 Know Of A Proper Fix
Posted by itsrelfy on 23 May 2015 - 03:45 PM
I just cleaned any muck off and used a clear silicone sealant from halfords made by Granville so you may need a cloth!!!
But they have now been stuck for about 9 months. I had to do 2 doors in quite quick succession. Back passenger side went first then front driver side.
But they've been fine ever since.
#488622 Mk7 Door Rubber Trim Falling Again Any1 Know Of A Proper Fix
Posted by itsrelfy on 22 May 2015 - 08:40 PM
They are the same in my focus. I just went to halfords and got some silicone stuck them back on and they have been fine ever since.
#463596 What Mk And Oil?
Posted by itsrelfy on 10 March 2015 - 12:56 PM
I think I'm right in saying that it's fully synthetic.
Ford do their own oil. Formula f 5-30 that's fully synthetic and is suitable for most modern fords with the exception of some transit and ka models I think.
If you go on opie oils they can help. You select which car and engine you have and it shows oil that is suitable.
Regards
Adrian
  • Ews likes this
#402415 Mini Cooper Wouldn't Start
Posted by itsrelfy on 28 August 2014 - 07:55 AM
Hi all
Don't know if anyone could help me she's any light in this.
Went out in my fiancés 2004 mini yesterday to get it cleaned then take it for it's mot. When we got to the car wash ( one of those hand jobbies) we switched off and waited until they had cleaned it and then got back in and it wouldn't start just a clicking noise.
So straight away I thought battery. Anyway the guys there helped me to bump start and it fired straight up.
Drove to it's mot in town and had no more starting issues.
Went to eurocar parts and picked up a new battery then travelled to my folks house 20 mile away. Borrowed my dads multi meter and it showed 12.5v. Went to install the new battery which incidentally didn't fit as it wasn't tall enough so the cables didn't fit on the terminals.
So reinstalled new one and the voltage was still good. Fired it up checked voltage whilst running and it showed 14.5v
So I know it's not a ford but do you think it could be a faulty starter motor or something else?
Any thoughts?
Adrian.
#387252 New Oil Filter
Posted by itsrelfy on 18 July 2014 - 12:55 PM
That's the same one as I got for my 1.6tdci. If you look under the turbo and down towards the ground you will see a black plastic cap with a 27mm nut on top. You need to unscrew that and the filter is in there.
It makes life easier if you remover the black air hose that goes into the turbo.
#359140 Some Issues With My Focus
Posted by itsrelfy on 01 May 2014 - 08:54 PM
I use she'll or esso fuel. Not the expensive stuff just normal diesel but I don't use supermarket stuff.
As for the phone I'll give it a try tomorrow.
